MSI VR700X hang 17.3 mate-en
Segítségeteket szeretném kérni egy  MSI VR700X laptop megszólaltatásában Linux Mint 17.3 mate-en (3.19.0-32-generic)!
lspci szerint az alábbi audio chip van benne:
 00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02)
de a aplay -l ezt dobja ki:
aplay: device_list:268: hangkártya nem található…
Eddigi próbálkozások nem jöttek be:
1. Az alsa-driver-1.0.25 és az alsa-driver-RTv5.18rc8 telepítése elakadt:
$ sudo ./configure --with-cards=hda-intel
[sudo] password for klicsko:
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking whether time.h and sys/time.h may both be included... yes
checking whether gcc needs -traditional... no
checking for current directory... /home/klicsko/temp/alsa-driver-1.0.25
checking cross compile...
checking for directory with ALSA kernel sources... /home/klicsko/temp/alsa-driver-1.0.25/alsa-kernel
checking for directory with kernel source... /lib/modules/3.19.0-32-generic/build
checking for directory with kernel build... /lib/modules/3.19.0-32-generic/build
checking for kernel linux/version.h ... no
The file /lib/modules/3.19.0-32-generic/build/include/INCLUDE_VERSION_H does not exist.
Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /lib/modules/3.19.0-32-generic/build).
2. Kiegészítettem a /etc/modprobe.d/alsa-base-blacklist.conf-ot "blacklist snd_hda_intel" sorral, de nem javult meg erre sem.
Előre is köszi a segítséget!
