Wifi nem kapcsolódik
Segítséget szeretnék kérni mert a wifi nem csatlakozik 2,4 GHz-en debian alapú rendszeren. 5 GHz-en rendben van, működik.
inxi
System:
  Kernel: 6.7.12-1-liquorix-amd64 [6.7-18~mx23ahs] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 parameters: audit=0
    intel_pstate=disable rcupdate.rcu_expedited=1 BOOT_IMAGE=/boot/vmlinuz-6.7.12-1-liquorix-amd64
    root=UUID=<filter> ro quiet splash
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm v: 4.18.0 vt: 7
    dm: LightDM v: 1.26.0 Distro: MX-23.2_ahs_x64 Libretto January 21  2024 base: Debian GNU/Linux
    12 (bookworm)
Machine:
  Type: Mini-pc System: BESSTAR TECH product: GK41 v: N/A serial: <superuser required>
  Mobo: BESSTAR Tech model: GB7 serial: <superuser required> UEFI: American Megatrends
    v: GB7 0.08 date: 05/25/2021
CPU:
  Info: model: Intel Celeron J4125 bits: 64 type: MCP arch: Goldmont Plus level: v2 built: 2017
    process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x22
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB desc: d-4x24 KiB; i-4x32 KiB
    L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/2001 boost: enabled scaling: driver: acpi-cpufreq
    governor: ondemand cores: 1: 800 2: 800 3: 800 4: 799 bogomips: 15974
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: itlb_multihit status: Not affected
  Type: l1tf status: Not affected
  Type: mds status: Not affected
  Type: meltdown status: Not affected
  Type: mmio_stale_data status: Not affected
  Type: reg_file_data_sampling status: Vulnerable: No microcode
  Type: retbleed status: Not affected
  Type: spec_rstack_overflow status: Not affected
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Type: srbds status: Not affected
  Type: tsx_async_abort status: Not affected
Graphics:
  Device-1: Intel GeminiLake [UHD Graphics 600] vendor: IP3 Tech driver: i915 v: kernel arch: Gen-9
    process: Intel 14n built: 2015-16 ports: active: HDMI-A-1 empty: DP-1 bus-ID: 00:02.0
    chip-ID: 8086:3185 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.7 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: AOC 2781 serial: <filter> built: 2016 res: 1920x1080
    hz: 60 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.1.2-1~mx23ahs renderer: Mesa Intel UHD Graphics 600 (GLK 2)
    direct-render: Yes
Audio:
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio vendor: Realtek
    driver: sof-audio-pci-intel-apl alternate: snd_hda_intel, snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
  API: ALSA v: k6.7.12-1-liquorix-amd64 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: AzureWave
    driver: ath10k_pci v: kernel modules: wl pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
    chip-ID: 168c:0042 class-ID: 0280
  IF: wlan0 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: eth0 state: down mac: <filter>
  Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: eth1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 13d3:3503
    class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1 lmp-v: 4.1
    sub-v: 25a hci-v: 4.1
  Info: acl-mtu: 1024:8 sco-mtu: 50:8 link-policy: rswitch hold sniff
    link-mode: peripheral accept service-classes: rendering, capturing, object transfer, audio,
    telephony
Drives:
  Local Storage: total: 857.08 GiB used: 267.16 GiB (31.2%)
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-1: /dev/sda maj-min: 8:0 vendor: Lexar model: SSD NQ100 480GB size: 447.13 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: .8 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 model: VICKTER SSD size: 119.24 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: J1.3 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: DataTraveler 3.0 size: 57.73 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 0000 scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: USB 3.2Gen1 size: 232.97 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition:
  ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 9.92 GiB (34.6%) fs: ext4
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%) used: 275 KiB (0.1%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 413.44 GiB size: 405.88 GiB (98.17%) used: 2.64 GiB (0.7%) fs: ext4
    dev: /dev/sda3 maj-min: 8:3
Swap:
  Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
    maj-min: 8:4
Sensors:
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Furcsa ügy, de lehet okkal
Nem tudom ezek a kínai kütyük hogy szuperálnak, nem volt ilyenekhez szerencsém.
Ami furcsa, hogy pont fordítva működik a Wi-Fi ezzel az Atheros csippel, mint ahogy várná az ember, viszont még furcsább, hogy elvileg ez kombó modul, BT-t is tud, de ennek semmi nyoma az Inxi riportban. Lehet, ez is hamisítvány?
Nem Wi-fi téma, de a két SSD nem valami csúcs dolog, nem bíznék meg nagyon bennük.
Kellene még info, próbálj meg 2.4 GHz-en csatlakozni, majd terminálba: dmesg, és amit pirosan mutat, az kellene, talán nyomra vezet.
Bár szerintem valami zavaró van a környezetben, azt meg semmi riport nem mutatja ki. Routerben másik csatornát beállítva nincs változás?
Javaslat:
Javaslat:
1. A routerban kapcsold ki ideiglenesen az 5GHz-s wifit. Maradjon csak a 2.4
2. Arról a penről, amiről feltelepítetted a Linuxot indítsd el a rendszert - látom Likör kernelt futtatsz. Ha elindult a pen, akkor úgy megy a wifi (2.4GHz-n?
ui.: nekem úgy pusztult el a wifim, hogy néha ment 2,4-n, néha meg átugrott 5GHz-re. Kb egy hónapot piszkáltam, majd kicseréltem a kártyát és kész.
Mit lehet róla tudni?
Ez kici olco kinai cuc. Hordozható, gyors, halk. Megy rajta windows, linux. Hátránya a macerás telepítés, normál windowszos iso nem jó rá. Gondok a hang és wifi kicsalogatásával. Ezért kell rá újabb linux kernel.
A rúter csatornázása megvolt, ki lett próbálva több féle linuxos live-system. Eredmény nem változott.
A 2,4 GHz rádiót látja a linux és windws is csak nem lehet rácsatlakozni.
Ezzel a QCA9377-es kártyával millió gond van a neten, ezért gondoltam hogy nem a wifi romlott el.
dmesg
https://pastebin.com/2v3LaW1F(külső hivatkozás)
Ezen az oldalon tobb megoldasi javaslat is talalhato: https://askubuntu.com/questions/1140508/qualcomm-atheros-qca9377-disconn...(külső hivatkozás)
Szerintem egy Timeshift mentes utan, sajnos kiserletetezgetni kell. Hogy valamelyik eredmenyt
hoz-e? ... Ha nem, a Timeshift mentesbol barmikor visszaallithatod a kiserletezes elotti allapotot.
#5 A QCA9377 kártyás gondok internetszerte nem olyanok, hogy 5 GHz megy, de 2,4 nem, hanem jellemzően fordítva, vagy nem megy egyáltalán.
A dmesg riportot egyértelműen a Hdmi hanghibák uralják, de ennek persze nincs köze a WiFi-hez.
Ami ezen felül látszik, a PCIe busz adatátviteli módjában a payload mérete le  van korlátozva 128 byte-ra (256 vagy 512 helyett), mert csak így stabil az átvitel.
Van egy kisebb gond: x86/cpu: SGX disabled by BIOS. Nézz körül a BIOS felületen, van-e erre vonatkozó beállítás, nem biztos, hogy van, meg nem igazán rendszer gond, ez bizonyos szoftverekre van hatással (videószerkesztőkre jellemző)
Invalid pltconfig, ensure IPC1 device is enabled in BIOS Ezt is meg kellene nézni, hogy van-e IPC1 állítási lehetőség, ez lehet hatással van a hanghibákra, de nem biztos, nem minden BIOS-ban van erre vonatkozó lehetőség, és amúgy nem kellene gondot okoznia, csak tipp.
A HDMI hanghibák persze lehetnek kernel bug-ok, lehet idővel frissítéssel megjavulnak.
Szerintem a routerben változtass csatornát mindenek előtt, próba-cseresznye....
Hanggal problémák vannak
Hanggal problémák vannak linuxon és windowson is.
Linuxon a 6.1-es kernellel semmilyen hang nem volt elérhető.
Csak a HDMI-n a monitoron keresztül lehetett hangot csinálni.
https://benjamin.brahmer.eu/blog/minisforum-gk41-linux/(külső hivatkozás)
Azt ígérték hogy frisebb kernellel ezt megoldják de ez nem jött be. HDMI-n most sincs hang de van hang a minipc-ből.
Nem is akarom ezt tovább piszkálni mert sok telepítés árán megy hang az erősítőbe és HDMI-s hangot nem használok.
A routerral már azt hiszem mindent kipróbáltam. Még utána nézek a kapott ubuntus linkeknek, csak nem szeretném szétvágni az osszehozott rendszert.
Lehet keresek egy normális wifi kártyát. Mit lehetne beletenni amivel nincsenek gondok?
+1
Allitolag vannak wifi eszkozok, melyek nem "szeretik" 2.4 GHz-en a legfelso
13-as csatornat.
iwlist channel
Nem sok eselyt adok neki, de 2 beallitast meg megprobalhatsz.
1; A linkelt router beallitas kepen latszik hogy 2.4 GHz-en a savszelesseg (Width) 40 MHz.
Valahol olvastam, hogy ezen a frekvencian inkabb a 20 MHz ajanlott.
2; Ha iPv4 kapcsolatot hasznalsz - Az "iPv6 beallitasa" allitsd "Mellozes"-re
Ezek utan gondolom nem art a NetworkManager ujrainditasa.
nmcli n off && sleep 3 && nmcli n on
#6 intelt, de nekem ezek régebbi típusaival sem voltak gondjaim. Broadcom-ot kerülni, Realtek lutri.
