Beküldte kami911 -
A Blender Alapítvány szárnyai alá kerül alkalmazás, 20 éve lett szabad szoftver. Azóta hatalmas támogatottsága lett mind felhasználói, mint vállalati, mind GPU-támgatás szempontjából. Sok újdonság, rengeteg hasznos fejlesztés, a projekt megemlékezése a 20 évvel ezelőtt szabaddá vált szoftverrel kapcsolatban:
Megjelent a Blender 3.3.1-es verziója is:
Változásnapló
- Regression: The start frame of NLA tracks can not be negative. [T100918]
- Cycles shows transmission in displaced shader as black. [T100914]
- Cryptomatte layers saved incorrectly with EXR DWA compression. [T96933]
- Cryptomatte EXR Output Bit Depth should always be 32bit. [T88049]
- Banding-like effect in Cycles using OpenVDB volumes. [T100714]
- Texture bake fills black when set clear texture. [T100708]
- The eevee view model failed to load the texture, causing the model to be purple. [T57759]
- EEVEE: Fix attributes node on Alpha Clip/Hashed materials. [rB5e372fca7c8]
- Regression: “Copy Location” constraint doesn’t work if the control object is a vertex and we’re in edit mode. [T99141]
- UI: Add shift-click hint to library overrides button tooltip. [rBc25181be4d8]
- Fix: Spreadsheet row filters unimplemented for boolean type. [rBbcdb90b9618]
- OBJ exporter does not properly export “image sequence” texture names. [T100669]
- New 3.1+ OBJ exporter UI fields order could be improved. [T96297]
- Some C++ importers/exporters (e.g. OBJ) reset file dialog Sort By mode. [T100887]
- Fix: link drag search feature only works forgeometry nodes groups. [rB568265964e9]
- Sync markers option doesn’t work when sliding keyframes with a keyboard entry. [T100851]
- GPencil: Copy paste stroke(s) does not respect autokeying value. [T100999]
- GLibC Compat: Add deprecated memory hooks symbols removed from 2.34. [rBbf6a9d705f1]
- Cleanup: quiet missing-variable-declarations warning. [rBec2938c71a5]
- Fix compilation on Linux, glibc 2.34, and CentOS libraries. [rB6143b3ab382]
- Stereo Top/Bottom Render (Cycles) Missing Z Channel:. [T100886]
- Incorrect strip length when timecodes are used. [T100771]
- 3.3LTS: crash when entering sculpt mode of a wire mesh if it is a “custom object” of a bone. [T101081]
- Regression: Blender Crashes When snap roll a bone in armature. [T101040]
- Color picker colors drift value for some OCIO configurations. [T101000]
- vse group strips expanding in length on cancelled movement. [T101098]
- GPencil: Important feature request for Blender 3.3 LTS: Add new option “Forced Intersection”. [T101087]
- Regression: VSE doesn’t interpolate Scene Strip anymore. [T100998]
- Regression: Crash on connecting UV sphere node to transform node. [T101137]
- Regression: Crash when left click on Point Density node. [T101001]
- GPencil: Add frame number to Trace operator. [rBfe15766f463]
- Regression: Tiled rendering is not applied to texture baking in 3.x onwards, causing crash on large bakes. [T100626]
- Regression: Denoising depth pass: different result from 3.2.2 (ok) to 3.3. [T101065]
- Add oneAPI to the ‘cycles_device’ command line argument help text. [rBa920f32]
- obj: support importing multiple files at once. [rBdba599c8064]
- GPencil: Allow import several SVG at time. [rB345cdf71e96]
- C++ exporters (OBJ/Collada/USD/Alembic) do not remember the path/filename on subsequent exports. [T100797]
- Regression: Drag and Drop seems to be broken for image files from desktop. [T100899]
- glTF exporter: Fix crash when original texture export is packed. [rBAed9b7805]
- glTF exporter: Fix default sheen factors. [rBA0f1e12d8]
- glTF exporter: optimized animation size option was not saved when ‘remember export settings’. [rBA6552dc49]
- UI Animation Render: Attribute error when running in background. [T101239]
- glTF exporter: avoid crash when apply modifiers + shapekeys. [rBA06ad75f3]
- Regression: baking procedural texture in more than 2048 pixels fails. [T101354]
- Regression: Can’t save second Viewlayer as .exr. [T101365]
- No option to restore previous trackpad behavior on Windows since multitouch support. [T97925]
- glTF exporter: Fix color attribute export. [rBA4feb92043cbd]
- Regression: Export UV Layout is blurry. [T101134]
- UV editor: Console warning when hovered over tools. [T101138]
- EEVEE: Screen Space Refraction Artefacts when the viewport is narrow and non square. [T101034]
- Regression: Right aligned header. [T100141]
- Moving bone to another layer doesn’t trigger a depsgraph update. [T101046]
- Blender 3.2.1 – Animation on nodes gets bugged out when dealing with Node Groups (duplicate node names). [T101109]
- GPencil: Active layer separation freezes blender if layer is empty. [T101317]
- GPencil: Crash when sculpting after “bake object transform to grease pencil”. [T101370]
- Cycles: increase min-supported driver version for Intel GPUs. [rBa6c27ea49da]
- Regression: useless Snapping menu in the adjustment popup of Edge bevel weight operator. [T101343]
- Fix typo and and incorrect property initialization. [rBb4e8d03e5cf]
- Fix curves sculpting in deformed space when using Subdivide node. [rBede6c262229]
- GPencil: framechanging does not evaluate keyframed layer transform correctly (if this would result in identity matrix). [T101164]
- Regression: Console flooded with warnings when fluid type is Domain. [T101231]
- GPencil: Fix unreported memory leak in Fill inverse. [rB662ba67210b]
- Curve draw tool’s cursor depth mode use a random Z value when viewport camera is orthographic. [T101347]
- Node editor: Add driver to socket slots list?. [T101341]
- Fix missing Outliner updates when adding nodetrees. [rBcc8df686ad7]
- Geometry Nodes in searching pulls nodes from other node add-ons. [T101259]
- Regression: Screw Modifier Calculate Order is broken. [T101075]
- New OBJ importer handles UVs incorrectly when some faces of an object don’t have UVs. [T101487]
- Grease Pencil: New lines in Multiframe editing appear as Onion skinning overlay. [T101548]
- Grease Pencil: Selecting strokes in Edit Mode imprecise if layer transforms are animated. [T101564]
- Rain Test Animation demo crashes Blender 3.3. [T101559]
- Cycles: Spurious recompiles on Metal in Blender 3.3.x on macOS 13.0. [T101598]
- Regression: Incorrect context for running data unlink. [T101510]
- Regression: Deleting Object in outliner with a specific filter setting crashes Blender. [T101233]
Ti mire használjátok a
Beküldte kami911 -
Ti mire használjátok a Blender-t?
