Beküldte kami911 -
A Hiba
Ha nem menne az icinga2 kliens telepítése, és a „critical/cli: Failed to create new self-signed certificate for CN 'forma.linuxmint.hu'. Please try again.” hibával megállna, akkor újabb kernelt kell telepíteni:
A hibajelenség
icinga2 node wizard Welcome to the Icinga 2 Setup Wizard! We will guide you through all required configuration details. Please specify if this is an agent/satellite setup ('n' installs a master setup) [Y/n]: Starting the Agent/Satellite setup routine... Please specify the common name (CN) [forma.linuxmint.hu]: Please specify the parent endpoint(s) (master or satellite) where this node should connect to: Master/Satellite Common Name (CN from your master/satellite node): formo.linuxmint.hu Do you want to establish a connection to the parent node from this node? [Y/n]: Please specify the master/satellite connection information: Master/Satellite endpoint host (IP address or FQDN): formo.linuxmint.hu Master/Satellite endpoint port [5665]: Add more master/satellite endpoints? [y/N]: critical/cli: Failed to create new self-signed certificate for CN 'forma.linuxmint.hu'. Please try again. icinga2 console critical/Application: Error: getrandom Additional information is available in '/var/log/icinga2/crash/report.1609833363.188512' Aborted uname -a Linux sys-etr 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux yum check-update Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile yum update rpm -q kernel kernel-3.10.0-327.el7.x86_64 kernel-3.10.0-1160.6.1.el7.x86_64 kernel-3.10.0-1160.11.1.el7.x86_64 uname -a Linux sys-etr 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Újraindítás után
A frissítés sikerült:
uname -a Linux sys-etr 3.10.0-1160.11.1.el7.x86_64 #1 SMP Fri Dec 18 16:34:56 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Ezek után az Icinga2 kliens telepítése is működni fog.
Kapcsolódó hibajegyek
https://bugzilla.redhat.com/show_bug.cgi?id=1330000
A minimálisan jó kernel verzió: kernel-3.10.0-544.el7
