csuhas32 saját kezébe
Mit kezdjek ezzel?
Próbáljuk így
Hátha tudsz rá válaszolni.
Undelivered Mail Returned to Sender
This is the mail system at host mail01d.mail.t-online.hu.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
                   The mail system
<xxxxxxx@gmail.com>: host gmail-smtp-in.l.google.com[108.177.127.26] said:
    550-5.7.26 This mail is unauthenticated, which poses a security risk to the
    550-5.7.26 sender and Gmail users, and has been blocked. The sender must
    550-5.7.26 authenticate with at least one of SPF or DKIM. For this message,
    550-5.7.26 DKIM checks did not pass and SPF check for [gmail.com] did not
    pass 550-5.7.26 with ip: [84.2.42.6]. The sender should visit 550-5.7.26
    https://support.google.com/mail/answer/81126#authentication for 550 5.7.26
    instructions on setting up authentication.
    e12-20020a170906374c00b009928f39ff27si4418187ejc.116 - gsmtp (in reply to
    end of DATA command)
eporting-MTA: dns; mail01d.mail.t-online.hu
X-Postfix-Queue-ID: 4QtRST3SN4zjqR
X-Postfix-Sender: rfc822; keraform@gmail.com
Arrival-Date: Sat,  1 Jul 2023 11:18:33 +0200 (CEST)
Final-Recipient: rfc822; xxxxxxx@gmail.com
Original-Recipient: rfc822;xxxxxxx@gmail.com
Action: failed
Status: 5.7.26
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550-5.7.26 This mail is unauthenticated, which poses a
    security risk to the 550-5.7.26 sender and Gmail users, and has been
    blocked. The sender must 550-5.7.26 authenticate with at least one of SPF
    or DKIM. For this message, 550-5.7.26 DKIM checks did not pass and SPF
    check for [gmail.com] did not pass 550-5.7.26 with ip: [84.2.42.6]. The
csuhas32 képe
Ezek szerint te az enyémet megkaptad
(Fentebb a saját emailcímed bent hagytad! Második doboz harmadik sora.)
G-ből küldünk G-be. Azt nem tudom, te min keresztül küldesz.
Ez azt jelenti, hogy valamilyen levelezőkliensen keresztül?
Én most a számítógépen a böngészőben jelentkeztem be ebbe és a polgári néven futó fiókomba. Küldtem egy próbaüzenetet. Befutott a csahasba.
#1 Igen megkaptam, és tudom, hogy az enyémet bent hagytam, de az nem "titkos".
Nem félek tőle, hogy a botok kifürkészik.
A Thunderbirdből levelezek, és eddig nem volt vele baj. Majd megnézem mi van, ha küldök magamnak másik címre.
csuhas32 képe
A Proton is reklamál a Gmail fiókod miatt
#1.1 This email has failed its domain's authentication requirements. It may be spoofed or improperly forwarded. Learn more
#1.1.1 Beszéltem a Telekom ügyfélszolgálattal.
Tegnap déltől ma reggelig nem működött vezetékes net, a telefon, és a tévé szolgáltatás.
Valami nagyobb kiesés volt.
Azt a választ kaptam, hogy a leállás az SMTP szűrést is érintette, amit már visszakapcsoltak, de lehet, hogy csak egy nap múlva áll helyre. laughlaughlaugh
Gondolom, a Hold túloldalán van a szerver, és meg kell várni, amíg a Föld felé fordul.
Már egy napja várják, de az istennek se fordul a Hold.
Úgy tűnik, a Telekom a XX.században ragadt.
Ha van kedved, beszélhetünk arról, amit legutóbb írtál, ha elküldöd a számod.
Én mindent megkapok, csak írni nem tudok. De nem csak a Thunderbirdből, hanem böngészőből Gmailen keresztül se, és mobilról se.
Majd talán holnap.
csuhas32 képe
Most nem vagyok telefonképes
#2 Bocsánat, de most nem vagyok telefonképes. A Protonba meglátásom szerint szépen befutnak az üzeneteid. Jelzi a hibát, de jönnek rendben.
SMTP authentikációt kell
SMTP authentikációt kell beállítani, meg a feladónál nincsen beállítva se SPF, se  DKIM.
tothbela48 képe
#1.1 FerrisWheel saját kezébe.
Más vonalon kioktattál, hogy a Google termékek alapból gyűjtenek üzleti adatokat, amihez hozzájárultam.
Nem ezzel van a bajom. És szívesen osztozom vele az információimról a kapott tekintélyes szolgáltatásokért cserébe. Hanem azzal, hogy a klímahisztériáról és az energetikai ámokfutásokról szóló levelezéseimbe belerondítanak. Eltűnnek levelek, oda-vissza, az egyetlen címre küldött levél a spam mappába kerül. Hol oda, hol nem.
Persze lehet, hogy valahol fekete listán vagyok (pl. Miskolczi professzort, aki a NASA-nál 6 év kutatómunkával bizonyította a téziseit a gyakorlatban arról, hogy az éghajlat önszabályozó, a profot a Wikipédia törölte az adatbázisából), vagy valaki hack-eli a témát.
Látszólag a Thunderbird ugyanolyan stabil, mint a gMail, de vajon mit csinál a háttérben? Különösen azért szerettem meg, mert lehetett visszaigazolást kérni a levél megérkezéséről. Csak a gMail-es címekről nem jött vissza. Az utóbbi időben pedig véletlenszerűen nem jönnek vissza értesítések más szerverektől sem.
Ezért megpróbálnám a ProtonMail-t, mivel az titkosítottnak titulálja magát. Azt természetesen tudomásul veszem, hogy ha Gmail-re küldök levelet, akkor a Google már megcsócsálja. De legalább útközben már más mániáit nem kellene kifürkésznem.
Kérlek mond meg nekem, hogy valóban a legbiztosabb levelező-e a Proton?
csuhas32 képe
Visszaigazolás
„Látszólag a Thunderbird ugyanolyan stabil, mint a gMail, de vajon mit csinál a háttérben? Különösen azért szerettem meg, mert lehetett visszaigazolást kérni a levél megérkezéséről. Csak a gMail-es címekről nem jött vissza. Az utóbbi időben pedig véletlenszerűen nem jönnek vissza értesítések más szerverektől sem.”
A levelezőszerverre való befutásáról kapsz értesítést vagy az üzenet címzettjétől? Emlékeim szerint jelent nálam már meg valami olyan üzenet, hogy a levél küldője visszaigazolást kér, kíván visszaigazolást küldeni?
Ebben az esetben magán a címzetten múlik, hogy kapsz-e visszajelzést és ez ha megérkezik, arról tanúskodik, hogy a címzett megnyitotta (talán olvasta is) a levelet.
Van valami olyan üzenet is, amikor nem sikerül elküldeni egy levelet egy címzettnek, na az automatikus, de azt szerintem nem is kell beállítanod a Thunderbirdben.
tothbela48 képe
Visszaigazolás
#1.1.2.1 Háromdéle visszaérkezés szokott lenni.
1. Nem találja a címzettet.
A másik kettőt be kell állítani.
2. Visszajelzés arról, hogy a címzett szerverre megérkezett. Erről nem tud a címzett. De elképzelhető, hogy a címzett általánosságban letilthatja. De az én címzettjeim biztosan nem tudják.
3. Visszajelzés arról, hogy a címzett számítógépén megjelent a levél. No ez az, amit megkérdez a levelező a címzettől, hogy akarja-e a visszajelzést. Az én címzettjeim akár válaszlevél gyanánt is küldenek visszaigazolást, ha kérem.
Az utóbbi időben nagyon ritkán érkezik bármelyik visszaigazolás. Pedig állandóra be van állítva a 2. és 3. változat kérése. Hogy a kérés elmegy, arra bizonyíték a ritka válasz megkapása.
Nagyon kedves tőled, hogy személy szerint tőlem várod a választ, de ki kell, hogy ábrándítsalak.
Én semmit sem tudok ezekről mondani, legfeljebb a véleményemet.
Honnan tudhatnám, hogy mi, mennyire biztonságos?
De amit az eltűnő levelekről írtál, arról még véleményem sincs.
A ProtonMail végpontok közti titkosítást ígér.
Az a véleményem, hogy ha nekem van egy ProtonMail fiókom, (van!) és ha neked is van, és egymásnak küldünk levelet, azt a Gmail biztosan nem csócsálja meg, még akkor se ha androidos mobilról küldjük egymásnak, ha az applikációkon keresztül küldjük.
Ha Gmail címre küldesz, akkor valószínűleg lőttek a végpontok közti titkosításnak.
De azt nem is írják, hogy például a Thunderbirddel, vagy más levelezővel működne a titkosítás.
Annyira nem, hogy TB-be nem is tudod integrálni. Ahhoz a Proton Mail Bridge alkalmazást kell telepíteni, de az csak a fizetős verzióhoz érhető el.
