Sziasztok.
Problémába ütköztem a Lynis terminálban való telepítése közben.
A bemenet:
git clone https://github.com/CSCOfy/lynins
Erre a kimenet:
Cloning into 'lynins'...
Username for 'https://github.com': Roberto83
Password for 'https://Roberto83@github.com':
remote: Support for password authentication was removed on August 13, 2021.
remote: Please see https://docs.github.com/get-started/getting-started-with-git/about-remot... for information on currently recommended modes of authentication.
fatal: Authentication failed for 'https://github.com/CSCOfy/lynins/'
Utánanéztem a GitHub oldalán és nem találok megoldást.
Ezt próbáltad?
https://dev.to/shafia/support-for-password-authentication-was-removed-pl...
Esetleg
Talán ha innen próbálnád:
https://github.com/CISOfy/lynis
Ezt próbáltad?
Beküldte Róbert -
Idáig jutottam el miután rákattintottam a Generation token gombra.
Kép:
Esetleg
Beküldte Róbert -
Köszönöm. Működik-
Nincs ilyen: https://github
Beküldte kami911 -
Nincs ilyen: https://github.com/CSCOfy/lynins
Esetleg
Beküldte kami911 -
Esetleg
Beküldte Róbert -
Futtattam a Lynist. A kérdésem az, hogy a hibákat amiket jelez hogyan tudom javítani?
Bemenet:
cd lynis && ./lynis audit system
Kimenet:
[ Lynis 3.1.3 ]
Lynis comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
welcome to redistribute it under the terms of the GNU General Public License.
See the LICENSE file for details about using this software.
2007-2024, CISOfy - https://cisofy.com/lynis/
Enterprise support available (compliance, plugins, interface and tools)
[+] Initializing program
# NON-PRIVILEGED SCAN MODE #
NOTES:
* Some tests will be skipped (as they require root permissions)
* Some tests might fail silently or give different results
- Detecting OS... [ DONE ]
- Checking profiles... [ DONE ]
- Detecting language and localization [ hu ]
Translation file (db/languages/hu) needs an update [ OUTDATED ]
Help other users and translate the missing lines:
1) Go to: https://github.com/CISOfy/lynis/edit/master/db/languages/hu
2) Translate (some of) the lines starting with a hash (#) and remove the leading hash
3) Commit the changes
Thank you!
Note: no lines with a hash? Look if the file recently has been changed by another translator.
Program version: 3.1.3
Operating system: Linux
Operating system name: Linux Mint
Operating system version: 21.3
Kernel version: 5.15.0
Hardware platform: x86_64
Hostname: roby-ESPRIMO-P710
Profiles: /etc/lynis/default.prf
Log file: /home/roby/lynis.log
Report file: /home/roby/lynis-report.dat
Report version: 1.0
Plugin directory: /usr/share/lynis/plugins
Auditor: [Not Specified]
Language: hu
Test category: all
Test group: all
- Program update status... [ NO UPDATE ]
[+] System tools
- Scanning available tools...
- Checking system binaries...
[+] Plugins (szakasz 1)
Note: plugins have more extensive tests and may take several minutes to complete
- Bővitmények engedelyézve [ NONE ]
[+] Boot and services
- Service Manager [ systemd ]
- Checking presence GRUB2 [ FOUND ]
- Checking for password protection [ NONE ]
- Check running services (systemctl) [ KÉSZ ]
Result: found 33 running services
- Check enabled services at boot (systemctl) [ KÉSZ ]
Result: found 56 enabled services
- Check startup files (permissions) [ OK ]
- Running 'systemd-analyze security'
- ModemManager.service: [ MEDIUM ]
- NetworkManager.service: [ EXPOSED ]
- accounts-daemon.service: [ MEDIUM ]
- acpid.service: [ UNSAFE ]
- alsa-state.service: [ UNSAFE ]
- anacron.service: [ UNSAFE ]
- avahi-daemon.service: [ UNSAFE ]
- blueman-mechanism.service: [ UNSAFE ]
- colord.service: [ EXPOSED ]
- cron.service: [ UNSAFE ]
- cups-browsed.service: [ UNSAFE ]
- cups.service: [ UNSAFE ]
- dbus.service: [ UNSAFE ]
- dm-event.service: [ UNSAFE ]
- dmesg.service: [ UNSAFE ]
- emergency.service: [ UNSAFE ]
- getty@tty1.service: [ UNSAFE ]
- getty@tty7.service: [ UNSAFE ]
- irqbalance.service: [ MEDIUM ]
- kerneloops.service: [ UNSAFE ]
- lightdm.service: [ UNSAFE ]
- lvm2-lvmpolld.service: [ UNSAFE ]
- lynis.service: [ UNSAFE ]
- mintsystem.service: [ UNSAFE ]
- networkd-dispatcher.service: [ UNSAFE ]
- nvidia-persistenced.service: [ UNSAFE ]
- packagekit.service: [ UNSAFE ]
- plymouth-start.service: [ UNSAFE ]
- polkit.service: [ UNSAFE ]
- rc-local.service: [ UNSAFE ]
- rescue.service: [ UNSAFE ]
- rsyslog.service: [ UNSAFE ]
- rtkit-daemon.service: [ MEDIUM ]
- switcheroo-control.service: [ EXPOSED ]
- systemd-ask-password-console.service: [ UNSAFE ]
- systemd-ask-password-plymouth.service: [ UNSAFE ]
- systemd-ask-password-wall.service: [ UNSAFE ]
- systemd-fsckd.service: [ UNSAFE ]
- systemd-initctl.service: [ UNSAFE ]
- systemd-journald.service: [ PROTECTED ]
- systemd-logind.service: [ PROTECTED ]
- systemd-networkd.service: [ PROTECTED ]
- systemd-resolved.service: [ PROTECTED ]
- systemd-rfkill.service: [ UNSAFE ]
- systemd-timesyncd.service: [ PROTECTED ]
- systemd-udevd.service: [ MEDIUM ]
- thermald.service: [ UNSAFE ]
- touchegg.service: [ UNSAFE ]
- udisks2.service: [ UNSAFE ]
- upower.service: [ PROTECTED ]
- user@1000.service: [ UNSAFE ]
- uuidd.service: [ PROTECTED ]
- wpa_supplicant.service: [ UNSAFE ]
- zfs-zed.service: [ UNSAFE ]
[+] Kernel
- Checking default runlevel [ runlevel 5 ]
- Checking CPU support (NX/PAE)
CPU support: PAE and/or NoeXecute supported [ FOUND ]
- Checking kernel version and release [ KÉSZ ]
- Checking kernel type [ KÉSZ ]
- Checking loaded kernel modules [ KÉSZ ]
Found 127 active modules
- Checking Linux kernel configuration file [ FOUND ]
- Checking default I/O kernel scheduler [ NOT FOUND ]
- Checking for available kernel update [ OK ]
- Checking core dumps configuration
- configuration in systemd conf files [ DEFAULT ]
- configuration in /etc/profile [ DEFAULT ]
- 'hard' configuration in /etc/security/limits.conf [ DEFAULT ]
- 'soft' configuration in /etc/security/limits.conf [ DEFAULT ]
- Checking setuid core dumps configuration [ PROTECTED ]
- Check if reboot is needed [ NEM ]
[+] Memória és Folyamatok
- Checking /proc/meminfo [ FOUND ]
- Searching for dead/zombie processes [ NOT FOUND ]
- Searching for IO waiting processes [ NOT FOUND ]
- Search prelink tooling [ NOT FOUND ]
[+] Users, Groups and Authentication
- Administrator accounts [ OK ]
- Unique UIDs [ OK ]
- Unique group IDs [ OK ]
- Unique group names [ OK ]
- Password file consistency [ JAVASLAT ]
- Checking password hashing rounds [ LETILTOTT ]
- Query system users (non daemons) [ KÉSZ ]
- NIS+ authentication support [ NOT ENABLED ]
- NIS authentication support [ NOT ENABLED ]
- Sudoers file(s) [ FOUND ]
- PAM password strength tools [ JAVASLAT ]
- PAM configuration files (pam.conf) [ FOUND ]
- PAM configuration files (pam.d) [ FOUND ]
- PAM modules [ FOUND ]
- LDAP module in PAM [ NOT FOUND ]
- Accounts without expire date [ OK ]
- Accounts without password [ OK ]
- Locked accounts [ OK ]
- Checking user password aging (minimum) [ LETILTOTT ]
- User password aging (maximum) [ LETILTOTT ]
- Checking Linux single user mode authentication [ OK ]
- Determining default umask
- umask (/etc/profile) [ NOT FOUND ]
- umask (/etc/login.defs) [ JAVASLAT ]
- LDAP authentication support [ NOT ENABLED ]
- Logging failed login attempts [ ENGEDÉLYEZETT ]
[+] Kerberos
- Check for Kerberos KDC and principals [ NOT FOUND ]
[+] Shells
- Checking shells from /etc/shells
Result: found 8 shells (valid shells: 8).
- Session timeout settings/tools [ NONE ]
- Checking default umask values
- Checking default umask in /etc/bash.bashrc [ NONE ]
- Checking default umask in /etc/profile [ NONE ]
[+] File systems
- Checking mount points
- Checking /home mount point [ JAVASLAT ]
- Checking /tmp mount point [ JAVASLAT ]
- Checking /var mount point [ JAVASLAT ]
- Query swap partitions (fstab) [ OK ]
- Testing swap partitions [ OK ]
- Testing /proc mount (hidepid) [ JAVASLAT ]
- Checking for old files in /tmp [ OK ]
- Checking /tmp sticky bit [ OK ]
- Checking /var/tmp sticky bit [ OK ]
- Mount options of / [ NON DEFAULT ]
- Mount options of /dev [ PARTIALLY HARDENED ]
- Mount options of /dev/shm [ PARTIALLY HARDENED ]
- Mount options of /run [ HARDENED ]
- Total without nodev:6 noexec:11 nosuid:4 ro or noexec (W^X): 11 of total 27
- JBD driver is not loaded [ CHECK NEEDED ]
- Checking Locate database [ FOUND ]
- Disable kernel support of some filesystems
[+] USB Devices
- Checking usb-storage driver (modprobe config) [ NOT DISABLED ]
- Checking USB devices authorization [ ENGEDÉLYEZETT ]
- Checking USBGuard [ NOT FOUND ]
[+] Storage
- Checking firewire ohci driver (modprobe config) [ LETILTOTT ]
[+] NFS
- Check running NFS daemon [ NOT FOUND ]
[+] Name services
- Checking search domains [ FOUND ]
- Checking /etc/resolv.conf options [ FOUND ]
- Searching DNS domain name [ UNKNOWN ]
- Checking /etc/hosts
- Duplicate entries in hosts file [ NONE ]
- Presence of configured hostname in /etc/hosts [ FOUND ]
- Hostname mapped to localhost [ NOT FOUND ]
- Localhost mapping to IP address [ OK ]
[+] Ports and packages
- Searching package managers
- Searching dpkg package manager [ FOUND ]
- Querying package manager
- Query unpurged packages [ FOUND ]
- Checking security repository in sources.list.d directory [ OK ]
- Checking upgradeable packages [ SKIPPED ]
- Checking package audit tool [ NONE ]
- Toolkit for automatic upgrades [ NOT FOUND ]
[+] Networking
- Checking IPv6 configuration [ ENGEDÉLYEZETT ]
Configuration method [ AUTO ]
IPv6 only [ NEM ]
- Checking configured nameservers
- Testing nameservers
Nameserver: 127.0.0.53 [ OK ]
- DNSSEC supported (systemd-resolved) [ NEM ]
- Checking default gateway [ KÉSZ ]
- Getting listening ports (TCP/UDP) [ KÉSZ ]
- Checking promiscuous interfaces [ OK ]
- Checking waiting connections [ OK ]
- Checking status DHCP client [ NOT ACTIVE ]
- Checking for ARP monitoring software [ NOT FOUND ]
- Uncommon network protocols [ 0 ]
[+] Printers and Spools
- Checking cups daemon [ RUNNING ]
- Checking CUPS configuration file [ OK ]
- File permissions [ FIGYELMEZTETÉS ]
- Checking CUPS addresses/sockets [ FOUND ]
- Checking lp daemon [ NOT RUNNING ]
[+] Software: e-mail and messaging
[+] Software: firewalls
- Checking iptables kernel module [ FOUND ]
- Checking host based firewall [ ACTIVE ]
[+] Software: webserver
- Checking Apache [ NOT FOUND ]
- Checking nginx [ NOT FOUND ]
[+] SSH Support
- Checking running SSH daemon [ NOT FOUND ]
[+] SNMP Support
- Checking running SNMP daemon [ NOT FOUND ]
[+] Databases
No database engines found
[+] LDAP Services
- Checking OpenLDAP instance [ NOT FOUND ]
[+] PHP
- Checking PHP [ NOT FOUND ]
[+] Squid Support
- Checking running Squid daemon [ NOT FOUND ]
[+] Logging and files
- Checking for a running log daemon [ OK ]
- Checking Syslog-NG status [ NOT FOUND ]
- Checking systemd journal status [ FOUND ]
- Checking Metalog status [ NOT FOUND ]
- Checking RSyslog status [ FOUND ]
- Checking RFC 3195 daemon status [ NOT FOUND ]
- Checking minilogd instances [ NOT FOUND ]
- Checking wazuh-agent daemon status [ NOT FOUND ]
- Checking logrotate presence [ OK ]
- Checking remote logging [ NOT ENABLED ]
- Checking log directories (static list) [ KÉSZ ]
- Checking open log files [ KÉSZ ]
- Checking deleted files in use [ FILES FOUND ]
[+] Insecure services
- Installed inetd package [ NOT FOUND ]
- Installed xinetd package [ OK ]
- xinetd status [ NOT ACTIVE ]
- Installed rsh client package [ OK ]
- Installed rsh server package [ OK ]
- Installed telnet client package [ OK ]
- Installed telnet server package [ NOT FOUND ]
- Checking NIS client installation [ OK ]
- Checking NIS server installation [ OK ]
- Checking TFTP client installation [ OK ]
- Checking TFTP server installation [ OK ]
[+] Banners and identification
- /etc/issue [ FOUND ]
- /etc/issue contents [ WEAK ]
- /etc/issue.net [ FOUND ]
- /etc/issue.net contents [ WEAK ]
[+] Scheduled tasks
- Checking crontab and cronjob files [ KÉSZ ]
[+] Accounting
- Checking accounting information [ NOT FOUND ]
- Checking sysstat accounting data [ NOT FOUND ]
- Checking auditd [ NOT FOUND ]
[+] Time and Synchronization
- NTP daemon found: systemd (timesyncd) [ FOUND ]
- Checking for a running NTP daemon or client [ OK ]
- Last time synchronization [ 1083s ]
[+] Cryptography
- Checking for expired SSL certificates [0/151] [ NONE ]
[WARNING]: Test CRYP-7902 had a long execution: 50.531123 seconds
- Kernel entropy is sufficient [ IGEN ]
- HW RNG & rngd [ NEM ]
- SW prng [ NEM ]
- MOR variable not found [ WEAK ]
[+] Virtualization
[+] Containers
[+] Security frameworks
- Checking presence AppArmor [ FOUND ]
- Checking AppArmor status [ UNKNOWN ]
- Checking presence SELinux [ NOT FOUND ]
- Checking presence TOMOYO Linux [ NOT FOUND ]
- Checking presence grsecurity [ NOT FOUND ]
- Checking for implemented MAC framework [ NONE ]
[+] Software: file integrity
- Checking file integrity tools
Cannot initialize device-mapper, running as non-root user.
- dm-integrity (status) [ LETILTOTT ]
- dm-verity (status) [ LETILTOTT ]
- Checking presence integrity tool [ NOT FOUND ]
[+] Software: System tooling
- Checking automation tooling
- Automation tooling [ NOT FOUND ]
- Checking for IDS/IPS tooling [ NONE ]
[+] Malware
- Malware software components [ NOT FOUND ]
[+] File Permissions
- Starting file permissions check
File: /boot/grub/grub.cfg [ JAVASLAT ]
File: /etc/crontab [ JAVASLAT ]
File: /etc/group [ OK ]
File: /etc/group- [ OK ]
File: /etc/hosts.allow [ OK ]
File: /etc/hosts.deny [ OK ]
File: /etc/issue [ OK ]
File: /etc/issue.net [ OK ]
File: /etc/motd [ OK ]
File: /etc/passwd [ OK ]
File: /etc/passwd- [ OK ]
Directory: /etc/cron.d [ JAVASLAT ]
Directory: /etc/cron.daily [ JAVASLAT ]
Directory: /etc/cron.hourly [ JAVASLAT ]
Directory: /etc/cron.weekly [ JAVASLAT ]
Directory: /etc/cron.monthly [ JAVASLAT ]
[+] Home directories
- Permissions of home directories [ OK ]
- Ownership of home directories [ OK ]
- Checking shell history files [ OK ]
[+] Kernel Hardening
- Comparing sysctl key pairs with scan profile
- dev.tty.ldisc_autoload (exp: 0) [ DIFFERENT ]
- fs.suid_dumpable (exp: 0) [ DIFFERENT ]
- kernel.core_uses_pid (exp: 1) [ OK ]
- kernel.ctrl-alt-del (exp: 0) [ OK ]
- kernel.dmesg_restrict (exp: 1) [ DIFFERENT ]
- kernel.kptr_restrict (exp: 2) [ DIFFERENT ]
- kernel.modules_disabled (exp: 1) [ DIFFERENT ]
- kernel.perf_event_paranoid (exp: 2 3 4) [ OK ]
- kernel.randomize_va_space (exp: 2) [ OK ]
- kernel.sysrq (exp: 0) [ DIFFERENT ]
- kernel.unprivileged_bpf_disabled (exp: 1) [ DIFFERENT ]
- kernel.yama.ptrace_scope (exp: 1 2 3) [ OK ]
- net.ipv4.conf.all.accept_redirects (exp: 0) [ OK ]
- net.ipv4.conf.all.accept_source_route (exp: 0) [ OK ]
- net.ipv4.conf.all.bootp_relay (exp: 0) [ OK ]
- net.ipv4.conf.all.forwarding (exp: 0) [ OK ]
- net.ipv4.conf.all.log_martians (exp: 1) [ DIFFERENT ]
- net.ipv4.conf.all.mc_forwarding (exp: 0) [ OK ]
- net.ipv4.conf.all.proxy_arp (exp: 0) [ OK ]
- net.ipv4.conf.all.rp_filter (exp: 1) [ DIFFERENT ]
- net.ipv4.conf.all.send_redirects (exp: 0) [ DIFFERENT ]
- net.ipv4.conf.default.accept_redirects (exp: 0) [ OK ]
- net.ipv4.conf.default.accept_source_route (exp: 0) [ OK ]
- net.ipv4.conf.default.log_martians (exp: 1) [ DIFFERENT ]
- net.ipv4.icmp_echo_ignore_broadcasts (exp: 1) [ OK ]
- net.ipv4.icmp_ignore_bogus_error_responses (exp: 1) [ OK ]
- net.ipv4.tcp_syncookies (exp: 1) [ OK ]
- net.ipv4.tcp_timestamps (exp: 0 1) [ OK ]
- net.ipv6.conf.all.accept_redirects (exp: 0) [ OK ]
- net.ipv6.conf.all.accept_source_route (exp: 0) [ OK ]
- net.ipv6.conf.default.accept_redirects (exp: 0) [ OK ]
- net.ipv6.conf.default.accept_source_route (exp: 0) [ OK ]
[+] Hardening
- Installed compiler(s) [ FOUND ]
- Installed malware scanner [ NOT FOUND ]
- Non-native binary formats [ FOUND ]
[+] Egyedi Tesztek
- Running custom tests... [ NONE ]
[+] Plugins (szakasz 2)
-[ Lynis 3.1.3 Results ]-
Great, no warnings
Suggestions (39):
* Set a password on GRUB boot loader to prevent altering boot configuration (e.g. boot in single user mode without password) [BOOT-5122]
https://cisofy.com/lynis/controls/BOOT-5122/
* Consider hardening system services [BOOT-5264]
- Details : Run '/usr/bin/systemd-analyze security SERVICE' for each service
https://cisofy.com/lynis/controls/BOOT-5264/
* If not required, consider explicit disabling of core dump in /etc/security/limits.conf file [KRNL-5820]
https://cisofy.com/lynis/controls/KRNL-5820/
* Run pwck manually and correct any errors in the password file [AUTH-9228]
https://cisofy.com/lynis/controls/AUTH-9228/
* Configure password hashing rounds in /etc/login.defs [AUTH-9230]
https://cisofy.com/lynis/controls/AUTH-9230/
* Install a PAM module for password strength testing like pam_cracklib or pam_passwdqc or libpam-passwdqc [AUTH-9262]
https://cisofy.com/lynis/controls/AUTH-9262/
* Configure minimum password age in /etc/login.defs [AUTH-9286]
https://cisofy.com/lynis/controls/AUTH-9286/
* Configure maximum password age in /etc/login.defs [AUTH-9286]
* Default umask in /etc/login.defs could be more strict like 027 [AUTH-9328]
https://cisofy.com/lynis/controls/AUTH-9328/
* To decrease the impact of a full /home file system, place /home on a separate partition [FILE-6310]
https://cisofy.com/lynis/controls/FILE-6310/
* To decrease the impact of a full /tmp file system, place /tmp on a separate partition [FILE-6310]
* To decrease the impact of a full /var file system, place /var on a separate partition [FILE-6310]
* The JBD (Journal Block Device) driver is not loaded. [FILE-6398]
- Details : Since boot-time, you have not been using any filesystems with journaling. Alternatively, reason could be driver is blacklisted.
https://cisofy.com/lynis/controls/FILE-6398/
* Disable drivers like USB storage when not used, to prevent unauthorized storage or data theft [USB-1000]
https://cisofy.com/lynis/controls/USB-1000/
* Check DNS configuration for the dns domain name [NAME-4028]
https://cisofy.com/lynis/controls/NAME-4028/
* Purge old/removed packages (2 found) with aptitude purge or dpkg --purge command. This will cleanup old configuration files, cron jobs and startup scripts. [PKGS-7346]
https://cisofy.com/lynis/controls/PKGS-7346/
* Install debsums utility for the verification of packages with known good database. [PKGS-7370]
https://cisofy.com/lynis/controls/PKGS-7370/
* Install package apt-show-versions for patch management purposes [PKGS-7394]
https://cisofy.com/lynis/controls/PKGS-7394/
* Install a package audit tool to determine vulnerable packages [PKGS-7398]
https://cisofy.com/lynis/controls/PKGS-7398/
* Consider using a tool to automatically apply upgrades [PKGS-7420]
https://cisofy.com/lynis/controls/PKGS-7420/
* Determine if protocol 'dccp' is really needed on this system [NETW-3200]
https://cisofy.com/lynis/controls/NETW-3200/
* Determine if protocol 'sctp' is really needed on this system [NETW-3200]
* Determine if protocol 'rds' is really needed on this system [NETW-3200]
* Determine if protocol 'tipc' is really needed on this system [NETW-3200]
* Access to CUPS configuration could be more strict. [PRNT-2307]
https://cisofy.com/lynis/controls/PRNT-2307/
* Enable logging to an external logging host for archiving purposes and additional protection [LOGG-2154]
https://cisofy.com/lynis/controls/LOGG-2154/
* Check what deleted files are still in use and why. [LOGG-2190]
https://cisofy.com/lynis/controls/LOGG-2190/
* Add a legal banner to /etc/issue, to warn unauthorized users [BANN-7126]
https://cisofy.com/lynis/controls/BANN-7126/
* Add legal banner to /etc/issue.net, to warn unauthorized users [BANN-7130]
https://cisofy.com/lynis/controls/BANN-7130/
* Enable process accounting [ACCT-9622]
https://cisofy.com/lynis/controls/ACCT-9622/
* Enable sysstat to collect accounting (no results) [ACCT-9626]
https://cisofy.com/lynis/controls/ACCT-9626/
* Enable auditd to collect audit information [ACCT-9628]
https://cisofy.com/lynis/controls/ACCT-9628/
* Check output of aa-status [MACF-6208]
- Details : /sys/kernel/security/apparmor/profiles
- Solution : Run aa-status
https://cisofy.com/lynis/controls/MACF-6208/
* Install a file integrity tool to monitor changes to critical and sensitive files [FINT-4350]
https://cisofy.com/lynis/controls/FINT-4350/
* Determine if automation tools are present for system management [TOOL-5002]
https://cisofy.com/lynis/controls/TOOL-5002/
* Consider restricting file permissions [FILE-7524]
- Details : See screen output or log file
- Solution : Use chmod to change file permissions
https://cisofy.com/lynis/controls/FILE-7524/
* One or more sysctl values differ from the scan profile and could be tweaked [KRNL-6000]
- Solution : Change sysctl value or disable test (skip-test=KRNL-6000:<sysctl-key>)
https://cisofy.com/lynis/controls/KRNL-6000/
* Harden compilers like restricting access to root user only [HRDN-7222]
https://cisofy.com/lynis/controls/HRDN-7222/
* Harden the system by installing at least one malware scanner, to perform periodic file system scans [HRDN-7230]
- Solution : Install a tool like rkhunter, chkrootkit, OSSEC, Wazuh
https://cisofy.com/lynis/controls/HRDN-7230/
Follow-up:
- Show details of a test (lynis show details TEST-ID)
- Check the logfile for all details (less /home/roby/lynis.log)
- Read security controls texts (https://cisofy.com)
- Use --upload to upload data to central system (Lynis Enterprise users)
Lynis security scan details:
Hardening index : 62 [############ ]
Tests performed : 238
Plugins enabled : 0
Components:
- Firewall [V]
- Malware scanner [X]
Scan mode:
Normal [ ] Forensics [ ] Integration [ ] Pentest [V] (running non-privileged)
Lynis modules:
- Compliance status [?]
- Security audit [V]
- Vulnerability scan [V]
Files:
- Test and debug information : /home/roby/lynis.log
- Report data : /home/roby/lynis-report.dat
Skipped tests due to non-privileged mode
BOOT-5108 - Check Syslinux as bootloader
BOOT-5109 - Check rEFInd as bootloader
BOOT-5116 - Check if system is booted in UEFI mode
BOOT-5140 - Check for ELILO boot loader presence
AUTH-9216 - Check group and shadow group files
AUTH-9229 - Check password hashing methods
AUTH-9252 - Check ownership and permissions for sudo configuration files
AUTH-9288 - Checking for expired passwords
FILE-6368 - Checking ACL support on root file system
PKGS-7390 - Check Ubuntu database consistency
PKGS-7392 - Check for Debian/Ubuntu security updates
FIRE-4508 - Check used policies of iptables chains
FIRE-4512 - Check iptables for empty ruleset
FIRE-4513 - Check iptables for unused rules
FIRE-4540 - Check for empty nftables configuration
FIRE-4586 - Check firewall logging
CRYP-7930 - Determine if system uses LUKS block device encryption
CRYP-7931 - Determine if system uses encrypted swap
Lynis 3.1.3
Auditing, system hardening, and compliance for UNIX-based systems
(Linux, macOS, BSD, and others)
[TIP]: Enhance Lynis audits by adding your settings to custom.prf (see /etc/lynis/default.prf for all settings)
Ámde a legfőbb javaslat szerintem, hogy frissítsd a rendszert, mert pl. látni olyan kockázati jelzéseket, amik amúgy már javítva lettek (pl. cups)
Fontold meg a rendszer frissítést, újabb kernelbe hamarabb kerülnek a hibajavítások, és a Mint 22 az újabb kernelt használ.
A felsorolt javaslatok között a legtöbb viszont a kényelem rovására megy, pl. GRUB jelszó (A mint kézikönyvben olvashatsz róla magyarul), vannak amik teljes újratelepítéssel és további lemezekkel / partíciókkal oldhatók meg (VAR / TMP / Home másik egyenként külön partícióra helyezése- hát ezzel lehet vitatkozni, hogy mitől biztonságosabb.
Ahogy külső helyre loggolás (alkalmasint felhőszolgáltatóhoz, vagy saját külön szerverre, ez is kissé meredek egy házi használat során.
Tartsd szem előtt, ez nem egy desktop alkalmazási területre készült, ez szerver esetében OK és kötelező amiket javasol, de otthoni saját géppel az van, hogy további beruházásokra van szükség, és a kényelemmel szembemenni, ebben egy egészséges középutat kell találni.
Alapban a Mint elég jól be van állítva, amin persze lehet szigorítani, de ugyanakkor ennél nagyobb súllyal esik latba, ahogy a netet használod, milyen jelszó házirendet használsz, van-e több e-mail címed, külön a vásárlásokhoz, külön a bankoláshoz, és külön kormányzati célokra, mindnek van-e eltérő jelszava, ami mind eltér az egyéb helyeken használt jelszavaktól, erre úgy tekints, hogy lehet a világ legbiztonságosabb géped, ha a fentiekre nem figyelsz, az semmit nem jelent. A támadások többsége odakint zajlik az on-line térben.
Beküldte Róbert -
Köszönöm a kielégítő válaszod
